i probably explained it wrong. the control signal can only give about 1.5amps (the connection right before the 4.7k in your latest circuit). that is what i am trying to limit. the relay part input amp part can be higher, no prob. like you said.First, I just deleted a mistaken entry. All of the circuits will produce, "drive on = relay on".
Use the MikeML circuit and add some resistance in the collector circuit. Probably less than 100 ohms.
However, I don't know why you want to mess about trying to take out 1.35 milliamps as if the relay board designer wanted a 5 volt circuit minus a tiny error caused by the value of R14.
is this possible?
also, i would like to bring back a pull resistor too, to stop the floating. the leds kind of just barely glow now that i am missing it while in the floating state (not activated).
thanks for bearing with me through this. i think we are very close to a solution.
