I would like to plug my woodworking router into a circuit that would monitor the amperage of the router motor. If the router is accidentally stalled (for any reason) and the amperage goes above a set point (1 to 7 amps) then the power to the router will be shut off.
What would be the easiest way to build a circuit like this? Are there any devices on the market that I would be able to use like this? I have seen industrial versions of this, but not low amperage 120 volt versions. Thanks in advance for any information about this circuit.
