Curious LED question
Discussion in 'General Electronics Chat' started by musicalavtech, Oct 4, 2013.
  1. musicalavtech
    Mar 23, 2012
    32
    If a 3 lead, red/green LED was switched between leads/colors at a rapid rate, would/could a brown color appear to be emitted?
  2. nigelwright7557
    May 10, 2008
    488
    71
    Yes, you can vary the colour between the two extremes.
  3. #12
    Nov 30, 2010
    16,705
    7,358
    Red light plus green light appears to be yellow. Switch them fast enough and persistence of vision will make them both appear to be on all the time, so theoretically, you will see yellow. A very dull yellow might be interpreted as brown, but I don't think so. There is also the consideration that some very poor quality LEDs exist. Some of them are hard to tell whether it's green or yellow in the first place.
  4. MrChips
    Oct 2, 2009
    12,656
    3,461
    You are thinking of red and green subtractive colors.
    If you mix red and green paint you get brown.
    However if you add red light to green light you will get yellow.
    #12 likes this.
  5. #12
    Nov 30, 2010
    16,705
    7,358
    Thanks. I couldn't place the reference to brown so I didn't make the required connection.
  6. shteii01
    Feb 19, 2010
    3,519
    515
  7. musicalavtech
    Mar 23, 2012
    32
    Ok then. My curiosity is cured...for now. Thanks.
  8. ErnieM
    Apr 24, 2011
    7,445
    1,628
    Last time I did this with a red & green LED it appeared as orange with both alternating on: you need the proper mix of red & green to get yellow.
  9. MrChips
    Oct 2, 2009
    12,656
    3,461
    Orange...yellow, close enough. Men don't know the difference!
    I'm sure if you increase the current it will look more yellow.
  10. shteii01
    Feb 19, 2010
    3,519
    515
    That is true. On our unit it was orange when I looked down when the unit was sitting on the table, so I was looking at the led sort of from the side. But when you looked straight at it, head on, then it is more yellow.
  11. mcgyvr
    Oct 15, 2009
    4,795
    979
    real men know the difference.. Its orange.. ;)
  12. ian field
    Distinguished Member
    Oct 27, 2012
    4,460
    792
    True - but if you dim it down to low current, the yellow will start to look brown.
  13. MrChips
    Oct 2, 2009
    12,656
    3,461
    So what color is it, yellow, orange or brown?
    If you dim it low enough it will appear black.:rolleyes:
  14. ian field
    Oct 27, 2012
    4,460
    792
    Orange is about midway between yellow & brown.
