Hello.
I hope I can explain this...........I have a 24vdc clock coil that will have two separate power supplies on two separate switches my problem is the what if......what if someone pushes in both switches at the same time how do I protect my circuit from supplying the coil with 48+ vdc what type of fuse or poly-switch should I use there isnt any current draw these coils use hardly no amps at all to operate .............hope this makes sense
