Curcuit Help needed
Discussion in 'General Electronics Chat' started by tenmen10, Jun 8, 2014.
  1. tenmen10
    Jun 8, 2014
    I am trying to wire a circuit, the board is a slightly different set up to what Im used too...What I am trying to do is have a simple on/off light system, turn on white light red off, red on white off, all via the remote fob..
    I have added a couple of pictures if anyone could help, I have blow two boards already so I am stumped, last time cracked it straight away, what am I missing.
  2. studiot
    Nov 9, 2007
    5,005
    515
    A circuit diagram?
    ErnieM likes this.
  3. tenmen10
    Jun 8, 2014
    I dont have one thats the problem, Im guess on where everything goes...
  4. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    From what I can see from the photo it uses a PT2272 remote control decoder.
    Bertus
  5. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Could the fact that relay terminal 'NC2' has apparently been mis-labelled 'NO2' be causing confusion?
  6. inwo
    Nov 7, 2013
    2,435
    315
    Is this a two button momentary?
    A two button toggle?
    How many buttons?
    The momentary won't do what what you want without more circuitry.
    If each button toggles a relay. One push for on. Push again for off. then it's pretty straight forward.
    It could also have two buttons for each relay. (latch)
    I use a lot of these, but don't know what you have.
    tenmen10 likes this.
  7. tenmen10
    Jun 8, 2014
    What would you need from me to help, I dont know enough about electronics to answer I figured out the NC was wrongly labelled, but its how I wire this....It came with a remote two button fob, I want to add white LED light to channel 1 and a red LED light to channel two....then then turn off as I switch channels...
  8. inwo
    Nov 7, 2013
    2,435
    315
    I need to know how it operates to determine if it does what you want.
    Connect 12 vdc positive to + and negative to -.
    With a finger on one of the two relays, press a button.
    Does it click when pressing a button? Is there a smaller click when button is released?
    Do the same with other button.
    ps.
    Do you have a link to where you got this?
  9. tenmen10
    Jun 8, 2014
  10. inwo
    Nov 7, 2013
    2,435
    315
    Now I see why you didn't supply more information.:D
    The link doesn't give much.
    I will assume that pressing "A" turns on relay "A".
    Pressing "A" again turns off relay "A".
    Same with "B".
    Does that seem right?
    Are your leds set up to run on 12volts dc?
    Proper current limit resistors?
  11. eetech00
    Jun 8, 2013
    678
    116
    I think your right because both relays are the same part number.
    eT
