cubes in a 4-d hypercube
Discussion in 'Homework Help' started by zulfi100, Jun 21, 2013.
  1. zulfi100
    Jun 7, 2012
    320
    Can somebody plz tell me:
    My answer is 3. I got it from the following link:
    https://en.wikipedia.org/wiki/Hypercube
    Zulfi.
  2. WBahn
    Mar 31, 2012
    18,085
    4,917
    How do you get 3 from that reference. They explicitly give a different number.
  3. zulfi100
    Jun 7, 2012
    320
    Thanks for your response. Sorry I dont see their answer. Kindly guide me.
    Zulfi.
  4. LDC3
    Apr 27, 2013
    920
    160
    Since the 4th dimension is beyond anyone's experience, all we can do is look at 3D shadows of 4D objects. The tesseract is the simplest object to view.
    To find out how many cubes are in a tesseract, go to the table in the middle of the web page. On the row that says 4-cube, look for the column that says cells. That is the number of cubes in a tesseract.
  5. zulfi100
    Jun 7, 2012
    320
    Thanks. It says 8.
    Zulfi.
  6. djsfantasi
    Apr 11, 2010
    2,900
    872
    Or draw the 3D projection of a tesseract and count the cubes directly. There is the inner cube, the outer cube (2 cubes) plus the projection between each of the 6 faces of these cubes (6 more cubes) giving 6+2=8.
  7. zulfi100
    Jun 7, 2012
    320
    I would try. But i have one related question. Are hypercubes possible in a 3d environment?
    Zulfi.
  8. WBahn
    Mar 31, 2012
    18,085
    4,917
    The 3-D projection of a 4-D object is a 3-D object. Think of it like a "shadow". You are a 3-D object but your shadow is a 2'-D object. The shadow of an n-D object is an object in (n-1) dimensions.
  9. zulfi100
    Jun 7, 2012
    320
    Thanks for your reply.
    Zulfi.
