CT to ADC
Dhanyakannan
Joined Mar 12, 2012
How will you connect a current transformer to an adc so that i can operate a microcntroller to control and enable load sharing for various current values?
pilko
Joined Dec 8, 2008
213
--Look at the burdon resistor on the schematic.
--Determine the max value of the burdon resistor (read attachment)
--If the BR is high enough to produce enough volts for the rectifier then use schematic as-is.
--If not ,you will need an op amp between the BR and the rectifier.
pilko
