I need a help. Can anyone help to find out the voltage drop across the 1.5R parallel resistor and effect of the rectifying diode on the circuit?
Here in the circuit image CT1 and CT2 are the current transformer leads of 1000:1 CT, that if there is 1000A in primary 1A in secondary.
My problem the CT current is bridge rectified using 1 schottky diode and one tvs diode as shown in image. As the current passes in primary the current will appear in the secondary. I have two 1.5R resistors as load resistor. I want to know how much voltage drop will be across CT. Whether the voltage will be 1A*0.75R (1.5R//1.5R) = 0.75Vdc or whether the diodes any have any effect on the voltage across the load resistor? Please help..
