CS amplifier problem.
Discussion in 'General Electronics Chat' started by alphacat, Nov 5, 2009.
  1. alphacat
    Thread Starter Active Member
    Jun 6, 2009
    186
    Hey,
    I built up the following circuit and for some reason I received VG = 0.38V, instead of VG = VCC/2.
    I have measured the resistance of RG2 when it was connected to the circuit, and the Fluke read 3.1KΩ.
    When I picked up RG1=RG2=100Ω, then VG was indeed VCC/2.
    Could someone explain it to me please?
    Does the Gate-Source have some kind of resistance? (around 3KΩ)
    Thank you.
  2. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    Did you connect it correctly?
    Greetings,
    Bertus
  3. The Electrician
    Oct 9, 2007
    2,301
    338
    You have probably damaged your MOSFET. Try a new one in the circuit.
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    I think electrician has nailed it. Extra care should be used when handling MOSFET devices. They are much more likely to be damaged by electro-static discharge than their BJT cousins.
    hgmjr
