guys i am attaching a picture of the circuit
anybody who knows to design it in proteus kindly design it with the graphs of input and output please
and send me that file here its urgent
yap i intended to use a NMOSFET ( n Channel)
Tell me the role of bypass capacitor please
and in which software you did it tell me
And did you used NPN transistor or N channel mosfet.
I think you used BJT and i want to do this with NMOS
I am trying to do with MOSFET but it ain't working
I do not think this configuration will work for a MOSFET well, it is meant for a BJT transistor. The two types of transistors are very different, they are not interchangeable.
For sure this circuit can work good withe MOSFET.
But to do this properly you need to know the TYPE of the mosfet and
Vt; K etc. Or find this parameters in data sheet.
Your Mosfet designs have the Mosfet operating where many are completely cutoff (Vgs less than the threshold voltage) and not working. You need to use enough gate-source voltage so that most or all of them are conducting enough current to work.
