Crystal types A and B
Discussion in 'General Electronics Chat' started by sirch2, Sep 28, 2013.
  1. sirch2
    Jan 21, 2013
    1,008
    351
  2. MaxHeadRoom
    Jul 18, 2013
    10,830
    2,500
    Depends what your application is, I have used run of the mill 38Khz crystals in PICmicro applications with good results.
    Max.
  3. ErnieM
    Apr 24, 2011
    7,434
    1,625
    Read the specs. A & B are case sizes.
  4. sirch2
    Jan 21, 2013
    1,008
    351
    Thanks for the replies. I thought I had read the specs, I was taking 3x8mm to be diameter x length, the B type doesn't actually give a size.
  5. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
  6. sirch2
    Jan 21, 2013
    1,008
    351
    Thanks Bertus
  7. MaxHeadRoom
    Jul 18, 2013
    10,830
    2,500
    If using them as a input to a T1 timer on a PIC for example, some vary slightly in the decoupling capacitor pair value.
    Max.
