Crystal Capacitors
Discussion in 'General Electronics Chat' started by Razor Concepts, May 5, 2010.
  1. Razor Concepts
    Thread Starter Active Member
    Oct 7, 2008
    212
    On microcontrollers, when using an external crystal, one uses small capacitors ~20pF across each crystal leg to ground. What are the purpose of these capacitors? Are they absolutely necessary?
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Those capacitors are needed.
    They are called "load capacitors"
    See the attached PDF's for more info.
    Bertus
    Razor Concepts likes this.
