Crystal capacitance
Discussion in 'General Electronics Chat' started by Flappie, Jan 9, 2014.
  1. Flappie
    Jan 7, 2014
    12
    I've been searching this forum and google'd a lot about it, but I can't find a clear answer to my question. Or let's say I don't know what's best for me.
    I'm using an ATmega644A-PU and I want to connect an external crystal of 20MHz to it. It will be connected like this:
    The crystal has a HC49 socket. I haven't bought the crystal yet, but I can choose between a crystal with a load capacitance (CL) of 50pF or one with a CL of 20pF. I can also choose one with a CL of 18pF (costs 1 cent more, so that won't be an issue :p).
    I also haven't bought the capacitors C1 and C2 yet.
    My question: which crystal is my best choice (what CL value)? What value do I choose for C1 & C2?
    The datasheet of my MCU tells me the recommended range for C1 & C2 is 12 - 22pF.
    The datasheets of these crystals tell me the shunt capacitance (C0) is 7pF maximum (I don't know whether this is relevant or not).
    Since I haven't bought any of these components yet, I'm trying to determine which components to buy in order to get the best setup.
    Thank you very much in advance!!
  2. Galen
    Jan 9, 2014
    I used to have crystals made for Mil Std equipment. Generally 20pf was the load value. It should be noted that if you get an order of 100 crystals, some may not be as tunable as others. Start-up is also an issue for certain circuit designs. The low frequency you are using shouldn't be a problem. Old timers would unsolder the case and lower the frequency with pencil lead or raise the frequency by pencil eraser.
  3. Flappie
    Jan 7, 2014
    12
    Thanks for your reply.
    I heard from others that 18pF for C1 & C2 is a 'general taken value.'
    Would it be a good setup to take 18pF for C1 and a crystal with a load capacitance of 20pF?
  4. MrChips
    Oct 2, 2009
    12,624
    3,451
    18pF is typical. You are not going to experience any problems with 12-22pF.
    Flappie likes this.
  5. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    The attached PDF's will tell you somethings about the loading capacitors.
    Bertus
    Flappie likes this.
  6. crutschow
    Mar 14, 2008
    13,475
    3,362
    Remember that your wiring and the microprocessor input will add several pF of stray capacitance which should be subtracted from the value for the added capacitors.
    Flappie likes this.
  7. alfacliff
    Dec 13, 2013
    2,449
    428
    unless your trying for extreme accuracy on the oscilator, dont worry about it too much the load capacitance will affect the crystal frequency a little bit. if too big, it may not oscilate.
    Flappie likes this.
