I have set up an RC circuit and some logic to discharge/charge and measure the time it takes for the cap to pull a TTL input pin high.
The R in RC is a linear pot used as a variable resistor. From the little I can remember from school, the time I measure should be proportional to R (since everything else in the circuit remains unchanged).
However what actually happens is that with bigger R the difference in time gets smaller.
I'd like to understand first if I am correct in thinking that t \(\propto\) R, and if so, why that does not happen on my desk.
Here is my setup:
Here is my setup:
