CRT Teardown
Discussion in 'General Electronics Chat' started by Georacer, Sep 17, 2013.
  1. Georacer
    Thread Starter Moderator
    Nov 25, 2009
    5,151
    1,266
    Hey everybody,
    I just took apart an old CRT TV (younger than me) and from the inside of the frame, around the tube/screen, there was a thick loop of wire. It was connected to the board, but not directly to any supply, if I traced it correctly.
    Does anybody have any idea what this was for?
  2. MrChips
    Oct 2, 2009
    12,648
    3,458
    Degaussing coil?
  3. #12
    Nov 30, 2010
    16,705
    7,354
    Yes. Degaussing coil. It is controlled by 2 thermistors. One is PTC, the other is NTC. Each the size of an American nickel. Each showing signs of heat.
    Georacer likes this.
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    Thanks.
    I found this over at Wikipedia:
    If this is true, then why is an NTC Thermistor used as well?
  5. #12
    Nov 30, 2010
    16,705
    7,354
    Series/shunt. One in series limits the current as it heats up, the other shunts the small remaining current after the limiter heats up and fails to completely stop all current.
  6. Georacer
    Nov 25, 2009
    5,151
    1,266
    Nice. As Destin says, "smarter every day".
  7. #12
    Nov 30, 2010
    16,705
    7,354
    As #12 says, "I learn something almost every day on this site".
    Anyway, happy to be an old TV guy that can explain extinct appliances.
  8. sheldons
    Oct 26, 2011
    616
    101
    that is the degaussing coil-on switch on it is pulsed to demagnetize the viewing area on the screen ....sometimes the ptc is responsible for a set being dead due to it blowing the mains fuse on switch on,they do tend to rattle a bit when you shake them if you have a faulty one.
  9. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    Most TV technicians also carried a degaussing coil with them, for manually D.G.'ing , consisted of a ~18" dia coil of wire and would be plugged int the nearest AC socket.
    I have seen it where someone doing the housekeeping uses the vacuum cleaner under the TV stand and happen to turn it off when under the set, and this can leave a nice pattern when the set is turned on which the degaussing coil does not eliminate fully.
    It temporarily magnetizes a screen in front of the CRT called a shadow mask deflecting the 3 primary colour beams .
    No longer happens with the LCD/LED sets.
    Max.
  10. #12
    Nov 30, 2010
    16,705
    7,354
    I still have mine.:p
    But then, I still have a CRT television that works.
  11. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    I just threw one in the garbage, 21st century and all that.. Hrumph ;)
    Max.
  12. wayneh
    Sep 9, 2010
    12,394
    3,246
    Haha, I'm watching one right now, and I'm still in a project to repair one for my daughter. It's not going well.
    Where I live, you have to pay to throw them away.
