Both are voltage waveforms. Blue one of the Timer555 and yellow of transistor. Yes it is de-coupled practically .What is the blue waveform? And the yellow one? Current? Voltage?
If there is power involved, it might be a good idea to decouple the supply voltage of the IC from the inductor & transistor.
Both traces are voltage traces.What are the traces?
Measured where?Both traces are voltage traces.
Isn't the diode preventing the overvoltage in this case? Like in the typical double-pulse testing?The open-circuit inductive kick as the transistor turns off can reach thousands of volts. By leaving out the snubber, you are causing the transistor to clamp at its breakdown voltage. There is finite probability that you will blow-up the transistor on any given time you turn it off (without the snubber).
how does these parameters effect on the working of the transistor??fT=unity gain bandwidth (i.e. nominal Freq at which device gain=1 under the specified conditions)
O/p Capacitance = output (i.e. collector) capacitance (tested as per the stated conditions)
Best regards
HP
Please re-read my previous reply -- I've amended it with further infohow does these parameters effect on the working of the transistor??
My purpose is that i was actually analyzing a waveform of the voltage of the transistor where i observed that when the transistor (MPSA42) should turn off , it turns off only for a moment and again shows some small swings , which i think is due to these parameters . BC547 shows proper results, it turns off for the entire expected period. i would attach the waveform for getting a clear idea.Limiting frequency Ft is defined three capacities (Cbe, Ccb and Cd_be=ie*tt/(K*T/e) T=300-->(K*T/e)=25.8mV)
Cbe=F(cje,Veb), Cbc=F(cjc,Vec).
I not comprehensible your purpose and I can not it is correct to answer the question.
Bordodynov.
A 12V dc motor is the load of the transistor.What is the load of the transistor? Fluctuations indicate the presence of inductance. Capacitance of the transistor and the inductor to form a resonant circuit. It should be borne in mind that the inductance can be real and spurious. I had an experience when the output of the repeater to the two transistors (PNP + NPN) was a surge voltage of up to two supply voltages. Then the reason was the long power wires. Bypass power pins condenser cleared up emissions. To reduce Fluctuations shunt power stage capacity. Use a wide and thick wires.
Bordodynov.
For the stated application (motor driver) fT and interelectrode capacitance are not important characteristics --- Ic (maximum collector current), hfe or 'beta' (forward transadmitance [essentionaly current gain]) and maximum interelectrode 'voltages' will be the significant considerations...A 12V dc motor is the load of the transistor.
by Duane Benson
by Aaron Carman
by Duane Benson
by Duane Benson
