critical thinking
Discussion in 'Homework Help' started by bujak18, Nov 17, 2008.
  1. bujak18
    Thread Starter Active Member
    Nov 12, 2008
    49
    :DUsing parallel circuit rules and Q,V,and C relationships, prove that Ct=C1+C2 for parallel capacitors.
    need at least a paragraph for an answer!
  2. boks
    Oct 10, 2008
    218
    Maybe change the topic?
  3. Ratch
    Mar 20, 2007
    1,068
    bujak18,
    No you don't. C1*V + C2*V = Q1 + Q2 = V(C1 + C2) . Ct = (Q1 + Q2)/V = C1+C2 .
    Ratch
  4. hgmjr
    Jan 28, 2005
    9,030
    214
  5. Bernard
    Aug 7, 2008
    4,240
    414
    Both replys from hgmjr's link & Ratch are good,if it will help I'll add some words. Prove the sum of individual caps. in parallel = to a single cap. C. As a given charge[Q] =CV, using two caps. C1 & C2 the charge on each is Q1=C1*V , Q2= C2*V, Q= Q1+Q2 or C1*V+ C2*V=CV; as caps are in parallel then all V's are the same, dividing by V gives: C1+C2=C
