Wow, Sharing porn with your wife? Weird.Thanks for your replies, BRreeves and mcgyvr.
Now I'm curious to see a photo (or a link) to a manual crimper costing 500 bucks or more. Somebody can post something? (I will show it to my wife! )
http://www.digikey.com/product-detail/en/te-connectivity-amp-connectors/1762846-1/A120092-ND/2040046Thanks for your replies, BRreeves and mcgyvr.
Wow!! We managed to beat out more glue from that poor horsey!
OMG! 2,580 dollars!
Yes, but there is a "huge" discount if you order 100 units.OMG! 2,580 dollars!
Honestly, for that price I was expecting some kind of desktop heavy "manual machine" keeping the wires and the connector both blocked in their micro-metric adjustable-position while crimping.
Yeah, I know that wires brakes always (soldered or crimped) after a while. In my case the connectors are not moving, they have a static (i.e. connected to the electric circuit of the motorcycle). My only concerns are about vibrations and durability against oxidation and (maybe) some water drops.If you have ever soldered jumper leads back onto the alligator clips then you have seen the wires break off right at the solder blob. There are some tricks we can use however to keep it from stressing right at the wire/solder interface.
For me this remains a big problem instead. I could make a soldered-joint but after how I seal it and protect from corrosion and water? Since the connector is not completely hidden int he fairing of the motorcycle, I cannot simply cover it with an unaesthetic "blob" of black siliconeI dont see why making a Y connector would be so hard to do.
Less than 120mA in the worst case.Is the current draw of your accessory available? Is it 1 amp, 3 amps, 10 amps, 30 amps?
So now we are up to 111 posts about a milliamp connection? What is wrong with pulling off from any power source in the protected headlight dome or under the seat? Any automotive splice kit will work.Less than 120mA in the worst case.
Sorry, I was not aware that threads should have a minimum amount of Ampere to be interesting.So now we are up to 111 posts about a milliamp connection? What is wrong with pulling off from any power source in the protected headlight dome or under the seat? Any automotive splice kit will work.
It's not that I don't know anything about the topic, it is the fact that it also took 113 posts to have you start explaining the magnitude and usage conditions of what you are trying to do. Don't you think that a picture like that should have been posted in your first or second post because motocross is a small subset of motorcycling? Read through this thread and let me know if you think the members had any idea of what you are trying to do.Sorry, I was not aware that threads should have a minimum amount of Ampere to be interesting.
If you propose a simple splice-device this means that you know nothing about motorcycle and their harsh environment conditions (expecially in off-road).
Ok, I will connect it to the usb-plug of my info-entertainment system by bridging it with the portatile-drink-cooler-set installed on my Cool4000-superlimousine-turbojet.
Just to give you an idea:
and.. "note the note"Starting at pg 50, with splicing terminals and going to the end where they call out the crimp inserts needed and the part number of the crimp tool.
Many of the butt splice terminals are designed for one wire at one end and two wires at the other.
Maybe it will help someone other than the OP
Not UL or CSA approved with use of multiple wires.
Not a big deal, the only risk the OP has is that his connected device will stop working unless he manages to short two splices together or a splice to the frame. In that case, the wet mud will likely keep the bike from bursting into flames.and.. "note the note"
Code:Not UL or CSA approved with use of multiple wires.
