Nice. Uses PWM internally, of course.look at the Zetex ZXLD1362 led driver
You can use a MC with the Zetek to control the LED.Nice. Uses PWM internally, of course.
Actually, I'm looking for a chip just like this but that can be controlled directly from a micro-controller - probably with a serial data input - instead of analog. I will check out Zetex.
It's more than simply PWM. It monitors the actual current flowing through the LEDs via the shunt resistor, and continually adjusts the PWM duty cycle to make the current as constant as possible.Nice. Uses PWM internally, of course.
Thread starter | Similar threads | Forum | Replies | Date |
Re-using CREE LEDs | General Electronics Chat | 42 | ||
BASIC LED DRIVER FOR 10 WATT CREE LED | General Electronics Chat | 47 | ||
B | Cree CXA1304 Driver | General Electronics Chat | 1 | |
Cree xm-l2 led related question | General Electronics Chat | 15 | ||
B | My first electronics project, array of 9 Cree XP-E2 with dimming | Digital Design | 9 |
by Duane Benson
by Duane Benson
by Don Wilcher
