Creation of Bar-Graph Clock from Scratch. HELP!
Discussion in 'The Projects Forum' started by Always?, Mar 17, 2011.
  1. Always?
    Mar 17, 2011
    I am a high school student making a digital clock with a bar graph display from scratch. I can easily find clock microchips online (the best I have found yet is at http://www.mouser.com/ProductDetail...S1302+/?qs=sGAEpiMZZMsWkX3fPoxIPfF9seFMN%2bTu), but how do I link this to a bar graph display? What circuit can I make to make a row of LEDS light up off of a clock output, one after the other?
    Please clarify excessively for me.
    Thanks.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The short answer is that you can't without a microprocessor in between to run the 3 wire serial interface. Grab the data sheet - use ds1302 as a search term.
    If you want to make a clock using a bar graph display, you might find that CD4017 decade counters will work nicely. It's easy to find digital clock designs.
    Almost forgot this one - http://forum.allaboutcircuits.com/showthread.php?t=51556
