thatoneguy
- Joined Feb 19, 2009
- 6,359
You could direct your C Compiler to output the .asm file. It would be a start for most, as it keeps the comments of the C program, in addition to the commands that created each assembler line.I don't know assembly, as I have had no experience in that regard. Perhaps you can make one using the algorithms I provided?
The variables usually aren't meaningfully named, and the way memory management is handled is a bit odd from an asm programmers viewpoint, but it would be translatable.
I don't know why so many stay with assembly on the PIC when there are great C compilers out there for free. Sourceboost creates tighter code than most new to assembly can code by hand.
