I am using a USB I/O device that allows my computer to detect whether a circuit is open or closed. My computer tracks the status of this input and stores it to a data file. Right now, if there is a bad connection I won't be able to detect it until it's too late and the data has been ruined.
I would like to have an LED that turns on when the circuit is closed, but I can't pass a current through the circuit that the computer is detecting. So, just sticking an LED in the circuit itself won't work.
Is there a simple solution? Can I somehow detect easily the change in resistance when the circuit closes and use that to turn on an LED?
Thanks for any advice you may be able to give!
