Creating a PCB with stripline inductors
Discussion in 'The Projects Forum' started by yoamocuy, Oct 20, 2011.
  1. yoamocuy
    Thread Starter Active Member
    Oct 7, 2009
    80
    Hey, I'm looking at building a test circuit provided in datasheet BLF571, and in this test circuit stripline inductors are used. In regards to the stripline inductors, the following information is given:
    Printed-Circuit Board (PCB): Rogers 5880; εr = 2.2 F/m; height = 0.79 mm; Cu (top/bottom metallization); thickness copper plating = 35 mm.
    My question is in regards to the height listed. Would that height be the thickness of the dielectric material between the inductor and the power plane/ground plane? Or would that be the height of the entire board?
  2. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
  3. BMorse
    Sep 26, 2009
    2,675
    234
    are you sure the thickness is 35mm not .35mm ??? That would be an awfully thick piece of copper! :)
  4. yoamocuy
    Oct 7, 2009
    80
    Oh its 35 μm :/
