ebeowulf17
- Joined Aug 12, 2014
- 3,307
Why is one contact on your relay tied to ground? Looks like when the relay is activated it will provide a dead short from 12V to ground. Am I misreading something there? Otherwise looks ok to me. Flyback diode connects in parallel across relay coil, reverse biased. See diagram in my last post.Alright I studied up a little on using a transistor and found this article here - http://www.technologystudent.com/elec1/transis1.htm. However, I am unsure where to put the flyback diode. I quickly drew up the attached circuit below which basically describes what I'm looking to do but just focuses on the PIN 6 output from the DCU as can be seen in my first post above. Is this basically how to use the transistor and where do I put the flyback diode if it's applicable to my application??
