Creating a 5V 20Hz pulse
Discussion in 'The Projects Forum' started by iONic, Oct 17, 2010.
  1. iONic
    Thread Starter AAC Fanatic!
    Nov 16, 2007
    1,422
    68
    I'm looking for a simple solution for making a 5V pulse at a frequency anywhere between 20Hz and 40Hz with 12VDC as a source. Also... a 50% duty cycle.
    Looking for the most compact solution...
    Perhaps a single IC with minimal external components can achieve this also.
  2. bradstormer
    Member
    Aug 6, 2010
    65
  3. tom66
    May 9, 2009
    2,613
    214
    What kind of accuracy are you looking for?
    For high accuracy (say ±0.001%) you can use a quartz crystal (32.768 kHz) and feed it into a binary ripple counter (divide by 16,384) to get 32 Hz.
    But if not, then a 555 timer as an astable is the next best solution. T = 1.1RC, so an R = 1k and a C of 3.3µF would get you 36.3ms nominal, which is 28 Hz.
  4. iONic
    Nov 16, 2007
    1,422
    68
    Yes, I was just playing with some 555 calculations. But from a 12V source I would also need a 5V voltage regulator triggered from a transistor on pin 3 of the 555. The part count starts to get large.
    Accuracy is a non issue, that's why I said between 20Hz - 40Hz. Not sure the exact value, but in the end if I'm shooting for 25Hz and I get 22Hz or 27Hz it would ne a non-issue.
    Do they make a single IC that could give a 5V TTL output as this would avoid additional parts with voltage regulation.
  5. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
  6. iONic
    Nov 16, 2007
    1,422
    68
    Yes, the Zener is a better option than the 78L05 VReg.
  7. tom66
    May 9, 2009
    2,613
    214
    A cheaper alternative is to use a 10k resistor and a signal diode (reverse polarity) to 5V. This will clip the signal to 0V to 5.7V which is fine for most applications, use a Schottky (slightly more expensive) to clip it to 5.3V.
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If you need a 50% duty cycle, you'll need a slightly more complex circuit.
    See the attached; output frequency is ~27Hz; however your mileage will vary with the accuracy of the timing capacitor.
    Note that C1 and C2 are required; these are stated in the datasheets as minimums. C2 can be larger if desired.
    If you want the frequency output to be adjustable, you could use a 20k potentiometer wired as a rheostat in series with R2, and reduce R2 to ~14k.
    Don't just use a pot for R2 however, as you will burn it up if you happen to adjust it too low in resistance.
  9. iONic
    Nov 16, 2007
    1,422
    68
    Thanks Sgt.
    The ultimate objective is to drive some LED's so that they do not appear to be turning on/off but rather to sort of pulsate, thus the exact duty-cycly and freq. are not hyper-critical. Not really knowing how it will look until it is visible leads me to think that some possible variation of duty-cycle and freq. would be helpfull during the design. Once I've determined the effect I want, fixed component values will be used.
    Thanks for your offering!
    i
