create an .exe file of a code in MATLAB
Discussion in 'Programmer's Corner' started by kahafeez, Jan 13, 2009.
  1. kahafeez
    Thread Starter Active Member
    Dec 2, 2008
    150
    Hi all, i need to make an .exe of my code in Matlab 7.0 bt i cant find the option.... plz help
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    You won't be able to do it with M-code because it requires the Matlab interpreter (a core-component of the Matlab application) to interpret and run the code.
    Dave
  3. yslassi
    Dec 21, 2008
    You can create your .exe from your .m code, just use mcc commande or Deploytool
    Youssef
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Interesting. Doesn't MCC require the Visual Studio compiler to enable the application to function without the Matlab interpreter as a standard executable file? I know nothing about DEPLOYTOOL, but a brief musing at Mathworks flags this http://blogs.mathworks.com/pick/2007/12/12/advanced-matlab-compiling-a-gui/
    Dave
