Create a shift on a square signal
Discussion in 'General Electronics Chat' started by kanoun, Apr 14, 2015.
  1. kanoun
    Jan 29, 2015
    41
    Hi guys,
    I need to create a 3 signals that are shifted from a reference one (see attached) S1 is the reference one, H is the clock. I'm trying to use a shift regester. My understing is that I need a in serie out series shift register. Is that true? anyway could you advise how to do so.
    I'm really not an expert in electronics.
    Many thanks for your help
  2. dl324
    Distinguished Member
    Mar 30, 2015
    3,375
    651
    Hi Kanoun,
    How is S1 being generated? Are there any constraints on how S2, S3, and S4 are generated?
    Is this a home work problem?
  3. kanoun
    Jan 29, 2015
    41
    S1 is generated with ne555
  4. dl324
    Mar 30, 2015
    3,375
    651
    Is using a couple of flip flops and 4 AND gates acceptable?
    Is the last waveform drawn correctly? Seems like it should be HI for the first half cycle of H.
  5. crutschow
    Mar 14, 2008
    13,469
    3,356
    Yes, you can use a serial-in shift register with parallel out.
    As Dennis asked, is this a homework problem?
  6. kanoun
    Jan 29, 2015
    41
    Many thanks guys ... Could you recommend how we connect cause I'm stuck with the one I have :(
  7. kanoun
    Jan 29, 2015
    41
  8. kanoun
    Jan 29, 2015
    41
    I did a mistake with the last one you're right.no it is not a homework ... I'm too old for homework :)
  9. dl324
    Mar 30, 2015
    3,375
    651
    Hi kanoun,
    You're device will work. Could also use half of a CD4015 or a CD4013 plus CD4011 (which I think is more interesting).
  10. kanoun
    Jan 29, 2015
    41
    Could you help with how to connect please
  11. ScottWang
    Aug 23, 2012
    4,924
    777
    1. What is the circuit uesed for?
    2. The S2 is going high when the S1 is at the falling edge.
    Assuming that there are S3 and S4 below the S2:
    3. S3 is going high when S2 is at the falling edge
    4. S4 is going high when S3 is at the falling edge
    S1 output is repeating:
    5. S1 is going high when S4 is at the falling edge.
    So, does what you want is a johnson counter?
    johnson counter d flip flop.
  12. crutschow
    Mar 14, 2008
    13,469
    3,356
    If you want to use the SN74HC595, then connect the RCLK and SCLK together to the H signal.
    Connect S1 signal to the SER input.
    Outputs QA, QB, and QC should have the signals you want.
    kanoun likes this.
  13. ErnieM
    Apr 24, 2011
    7,434
    1,625
    I do not see where the "H" signal is being generated.
    kanoun?
  14. dl324
    Mar 30, 2015
    3,375
    651
    It's equally unclear how S1 is being generated (aside from 555 timer without a schematic) and how it's waveform is being synch'ed to H. If the HI/LO times aren't controlled sufficiently, using a shift register might not give the desired results.
    Much simpler to use a couple flip flops and a pack of AND gates.
  15. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    There is a discrepance in your drawing.
    You are stating 50 seconds for a cycle, I come to 40 seconds:
    When you have the "H" signal, use it to clock a 4017 and reset it at the wanted number of pulses.
    Bertus
  16. kanoun
    Jan 29, 2015
    41
    Yes yo
    yes you're right ... It is a mistake when I drowed the signals :) ... Anyway Ill use the 4017 I finally understood how it's work ...
  17. AnalogKid
    Aug 1, 2013
    4,679
    1,295
    OR, what about a CD4017? Tie output 4 to the Reset input.
    ak
    kanoun likes this.
