CRC errors in Ares Proteus 8
Discussion in 'Programmer's Corner' started by hbtalvi@hotmail.com, Jul 3, 2013.
  1. hbtalvi@hotmail.com
    Jul 3, 2013
    I did auto routing of a circuit on a signal layer but getting 24 CRC errors after that, Kindly help how to remove them and what basically is a CRC error?
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Have you contacted Labcenter and filed a bug report?
  3. ErnieM
    Apr 24, 2011
    7,442
    1,628
    A CRC error is a cyclic redundancy check error and it pertains to the software or file being corrupted. It has nothing to do with the board design or routing itself.
    Perhaps you meant instead a DRC error which stands for Design Rule Check error... these come about from some feature not meeting a global rule.
    Each error must be inspected in turn to see if it is a real rule violation needing to be fixed (rerouted, moved, whatever) or if the rule itself is improper (such as not allowing pads to be placed close enough to accommodate the IC's in your design).
  4. t06afre
    May 11, 2009
    5,939
    1,222
    In this case CRC=Connectivity Rule Checker, and not cyclic redundancy check[​IMG]
    CRC establishes which pins are connected to each other (by tracking and vias) and compares this with which pins have been assigned to the same net in the netlist. If you click on the items in the list, the net or nets affected by the error will be highlighted. If you design from a netlist in the first place, and especially if you use the auto-router, you are unlikely to make mistakes other than missing connections out.
  5. WBahn
    Mar 31, 2012
    18,089
    4,917
    So is there a difference between CRC and LVS (layout versus schematic)?
