1) correct me if I am wrong , If I buy a cpu it comes with the coolant system. I.E heat sink , fans , perhaps thermal compound...etc
2) Is it possible to buy just the coolant system without the cpu. Like just the heat sink and the fan ,...etc
3) What coolant technology is the best (i.e dissipates the most heat...)
Is it peltiers , water coolant , heat sink/fan , or something completely different that I am not aware of
4) how interchangeable are the coolant systems for the cpu's?
For instance if I look at the spec's of a heat sink and it say's it can dissipate X amount of heat at a certain rate and my cpu never heats up that quickly to that rate. Then I should be safe in using that heat sink.
Or is their other factors I am overlooking?
