CPP class pointer doubt
Discussion in 'Programmer's Corner' started by ep.hobbyiest, Mar 30, 2016.
  1. ep.hobbyiest
    Aug 26, 2014
    94
    I m new to cpp. I have doubt in following code. Doubt is regarding pointer. here is code
    Code (Text):
    1.
    2. // pointer to classes example
    3. #include <iostream>
    4. using namespace std;
    5. class CRectangle {
    6.     int width, height;
    7.     public:
    8.     void set_values (int, int);
    9.     int area (void) {return (width * height);}
    10. };
    11.
    12. void CRectangle::set_values (int a, int b) {
    13.     width = a;
    14.     height = b;
    15. }
    16.
    17. int main () {
    18.     CRectangle a, *b, *c;
    19.     CRectangle * d = new CRectangle[2];
    20.     b= new CRectangle;
    21.     c= &a;
    22.     a.set_values (1,2);
    23.     b->set_values (3,4);
    24.     d->set_values (5,6);
    25.     (*(d+1)).set_values (7,8);
    26.     cout << "a area: " << a.area() << endl;
    27.     cout << "*b area: " << b->area() << endl;
    28.     cout << "*c area: " << c->area() << endl;
    29.     cout << "d[0] area: " << d[0].area() << endl;
    30.     cout << "d[1] area: " << d[1].area() << endl;
    31.     delete[] d;
    32.     delete b;
    33.     return 0;
    34. }
    35.
    36.
    from the line
    Here d is array which dynamically allocated. but when we are accessing area() function that time we have to use -> instead of ".". but, we are accessing set_value function using dot operator even though it is pointer.
    So, i m confused when to use arrow operator and when to use dot operator.
  2. vpoko
    Member
    Jan 5, 2012
    258
    47
    When you point to an array, the array's element 0 is at the address the pointer points to, element 1 is at that address plus the size of the pointer (also the size of each element of the array), element 2 is at that address plus twice the size of the pointer, and so on. When you say d->set_values(4,5) on line 24, you are hitting element zero of your array using the equivalent pointer notation (you use the arrow because d is, in fact, a pointer, and the arrow is syntactic sugar for deferencing. You could do the same thing with (*d).set_values(4,5) and not use the arrow). Likewise, you can work with d like an array (C mostly lets you treat a pointer to an array like the array itself, think of the [] as another shortcut for the dereference operator). d[0].set_values(4, 5). Why the dot in this case? Because d[0] is not a pointer, it is a reference to a CRectangle instance. References and pointers are similar but not identical, and one of the differences is that references dereference automatically.
  3. vpoko
    Member
    Jan 5, 2012
    258
    47
    No, the OP was trying to understand it, not saying something was wrong with it.
