Cows Dying Of Electrocution on Farm
Discussion in 'Off-Topic' started by bwilliams60, Oct 20, 2015.
  1. bwilliams60
    Thread Starter Active Member
    Nov 18, 2012
    734
    94
    I just heard on the news that a local farmer has cows dying of electrocution on his farm. Apparently there are "stray" currents running through his property (Earth) and putting his cows down. If this is the case, how is it so? I understand Earth to be zero voltage reference for all things electrical. Am I wrong in thinking this? I realise that ground is part of a circuit going back to the generating station but it is so widespread, how can a concentrated amount be killing his cows? Do they have no resistance? I am perplexed in Ontario, Canada?
  2. blocco a spirale
    Jun 18, 2008
    1,460
    370
  3. GS3
    Sep 21, 2007
    408
    35
    "there was leakage of electricity from a cable under the parade ring in the area where the incident occurred."
  4. spinnaker
    Oct 29, 2009
    5,074
    1,176
    Yikes! I have never heard of this. Cows are bad enough. Good thing no humans walked these same grounds.
  5. blocco a spirale
    Jun 18, 2008
    1,460
    370
    Probably not much risk to humans since we normally wear shoes with synthetic soles and our feet are closer together. There is also the position of the heart in relation to currents flowing between the feet which, I think, is likely to be more significant for four-legged animals.
    #12 likes this.
  6. ErnieM
    Apr 24, 2011
    7,436
    1,626
  7. GopherT
    Nov 23, 2012
    6,308
    4,029
    The "stray voltage" that farmers talk about has nothing to do with direct contact to a cable. When I was growing up in central minnesota, there was a big deal of a new power line going through some farms. These farmers were complaining how bad these high voltage lines were and protested and protested until, you guessed it, they got the price they wanted for each pole on their property or power line running over their property. There were various hoaxes of cows near by getting electrocuted by other power lines. News stories of a farmer showing how he could light a small bulbs by simply holding a transformer under the power line - not even connected to the plug - they called it "stray voltage".
    I think the OP should investigate the possible ulterior motives of the farmer before he looks for technical reasons for an electrocution.
    EDIT: I am no longer convinced of my information above- read the link in Post 16 below.
    #12 likes this.
  8. strantor
    Oct 3, 2010
    4,302
    1,989
    Apparently post mortem electrocuted horses store a capacitive charge:
    I'm calling bull. Someone realized they bet too much money on a hopeless horse and so killed the competition. Multiple parties have motive to cover that up.
    #12 likes this.
  9. blocco a spirale
    Jun 18, 2008
    1,460
    370
    The horse was probably still lying on the electrified ground when it received "immediate veterinary attention".
  10. alfacliff
    Dec 13, 2013
    2,449
    428
    there is current flowing through the earth,, tryh putting two rods into the ground spaced apart, and an ac volt meter connected to them. often you will find current flow. houses and power lines with unballanced current in the phases feeding them cause ground currents to flow back to the power line or power plant.
  11. strantor
    Oct 3, 2010
    4,302
    1,989
    Ok, fair enough. But "electrified ground" ... isn't that an oxymoron?
  12. blocco a spirale
    Jun 18, 2008
    1,460
    370
  13. bwilliams60
    Nov 18, 2012
    734
    94
    OK so far no reasonable explanations? This is a problem big enough to warrant our hydro company to get involved so it is real. The guy has lost over 100 cows in 13 years and has roughly 2 volts and 800mA running through his property. He has installed a couple of boxes which cut the stray voltage in half so I don't think this is a hoax. My questions still remains, "how is it possible"?
  14. GopherT
    Nov 23, 2012
    6,308
    4,029
    Center tapped transformers (grounded center tap) with unbalanced loads. Farm is between the usage point and power plant.
  15. bwilliams60
    Nov 18, 2012
    734
    94
    Okay now we are getting somewhere. Apparently another farmer sued the government and won so it is a real problem. I seen a bill that was put forth to the government and passed two readings. Makes you wonder?
  16. GopherT
    Nov 23, 2012
    6,308
    4,029
