cout << (--i)-- << " "; and the answer is?
Discussion in 'Programmer's Corner' started by summeranson, Sep 24, 2009.
  1. summeranson
    Feb 12, 2009
    28
    If i = 5, what will be the result of:
    do
    } while(i>=2 && i < 5);
    A. It won't enter the loop
    B. It will loop forever
    C. I don't know
    D. Compiler error
    E. 4 3 2 1
    F. 4 3 2
    G. 4 2 1
    H. 4 2
  2. mik3
    Feb 4, 2008
    4,846
    63
    The answer is very easy.
    What do you think?
    What you don't know?
  3. summeranson
    Feb 12, 2009
    28
    i think the answer is H issit? i am not sure about the -- behind the (--i)--
  4. mik3
    Feb 4, 2008
    4,846
    63
    I think the answer is A because i=5 and it will never enter the loop.
    Another possible answer is D because of (--i)-- but I think it is possible to use both --i and i-- in C but with a slightly different functionality.
  5. odinhg
    Jul 22, 2009
    65
    15
    The answer is H.
    i = 5;
    do{
    First it will enter the loop before checking that i>=2 and i<5 because it's a do-while loop.
    Then it will decrease i by 1 and print it (i-1 = 4), then decrease it by 1 another time.
    Now i is 3 and i>=2&&i<5 is true, so it will run the loop again.
    Decrease i with 1, which gives us 2 and print it, then decrease it with 1 another time.
    Now i is 1, so i>=2&&i<5 is false and the loop stops.
