I have two audio stages to connect.
The circuits are taken from the datasheets of the IC's. Would you use both capacitors C8-C6 (right channel) and C9-C7 (left channel) in series or just one cap? If just one cap, what value? Any resistors needed? Side note: The output impedance of the SI4735 chip is about 20K, the input to the TDA7052 is 10K.
