Counting pulse
Discussion in 'The Projects Forum' started by Santosh_16k, Aug 20, 2011.
  1. Santosh_16k
    Aug 19, 2011
    19
    I require a pulse counter circuit for my project.I want it to stop generating pulses after 'n' pulses. How do I achieve this???I don't want to use micro controllers or micro processor.
    Which IC should I use????
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Put a ripple counter on it, a AND gate, and another AND gate between the pulse generator and the output.
  3. praondevou
    Jul 9, 2011
    2,936
    489
    As Bill said , it's easy to do it with a counter and basic logic gates.
    You should however mention how many pulses is "n" and if it has to be adjustable and if so what's the range (n max / n min).
  4. KMoffett
    Dec 19, 2007
    2,586
    234
    0-99 with a CD40102 pre-settable down counter and a couple of decimal thumb wheel switches. Expandable.
    Ken
  5. Santosh_16k
    Aug 19, 2011
    19
    Can u show me the circuit diagram....
    The no. of pulses I needed is only 20...
    When a high signal is given,the circuit should give only 20 pusles and stop till the next high signal is given to it. This should b repeated for every high signal....
  6. KMoffett
    Dec 19, 2007
    2,586
    234
    Details...details....details. ????
    Operating voltage?
    Input pulse width?
    Input source...switch?...TTL?...CMOS?
    Output load?
    Frequency of output pulses?
    20 pulses or settable from 1 to 20 pulses?
    How to set...jumpers?...DIP switches?...thumb-wheels?
    Output pulses start synchronous with start-pulse edge?
    ken
