Counters & Shift Registers
Discussion in 'Homework Help' started by jtyler, Feb 18, 2010.
  1. jtyler
    Feb 2, 2010
    6
    Looking for an example for this kind of situation explained by my professor for an upcoming test.
    We will be designing in Quartus using block diagram/schematic file.
    3 counters: (can use LPM)
    counter1) holds data with a specific count sequence
    counter2) rolls over and clocks the shift registers
    counter3) rolls over and is a divide by counter that is counting down the system clock to a reasonable level
    2 registers (SIPO and PISO)
    -clocks data from data register parallel in to PISO
    -then shifts serially to SIPO
    -then clocking it out parallel out to board
