Counters GATE time setting?
Discussion in 'General Electronics Chat' started by LeoWilson, Oct 3, 2014.
Thread Status:
Not open for further replies.
  1. LeoWilson
    Oct 3, 2014
    10
    How do you know what to set the GATE time on counters?
    Does it depend on how long the waveform/signal is? or how long the single event trigger time is?
    If you set the Gate time to short it will give a false time reading?
    Also there is a Delay knob on counter to set the stop circuit. When do you use this and how do u set it?
  2. GopherT
    Nov 23, 2012
    6,315
    4,035
    Since you were thorough enough to include a make and model number, I will advise you to read the instruction manual. Many (most) are available on-line. Amazing amount of information in those things.
  3. LeoWilson
    Oct 3, 2014
    10
    Yes i did read the manuals but it doesn't say what to set the GATE time or the Delay time , depending on the length or how long the time duration of the waveform you're countering
  4. GopherT
    Nov 23, 2012
    6,315
    4,035
    Ok then, since you managed to post a link to the manual, and told us a little bit about the application, frequency and noise conditions, i will get to work looking that up for you.
  5. LeoWilson
    Oct 3, 2014
    10
Thread Status:
