counter using Realys
Discussion in 'The Projects Forum' started by viveksrivastava16, May 18, 2011.
  1. viveksrivastava16
    May 18, 2011
    i want to make counter using Realys or Actually i have one input and one output...when first time input come than output is on and again when input come so output is off.....please help me of making this with tha help of Relays....
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    Isn't he obliged to construct a Flip Flop using relays as logic gates from scratch? Apart from logic gate implementation ideas, I don't see how the .pdf helps the OP.
    I think after he reads the site he should see the flip flop internal structure and try to mimic it:
    http://www.allaboutcircuits.com/vol_4/chpt_10/6.html
    Would SR latches be needed to debounce the clock input and every relay contact?
    viveksrivastava16 likes this.
  4. mannycc
    Dec 11, 2010
    17
    Would suggest to mimic the master-slave type J-K or D flip flop internals using relays to keep the switch from racing unpredictably.
