counter using logic gates
Discussion in 'General Electronics Chat' started by proctor1, May 14, 2016.
  1. proctor1
    May 12, 2016
    I need to count pulses from a bill accepter and send a pulse when it counts a programmable(dip switch?)determined number.
  2. dl324
    Distinguished Member
    Mar 30, 2015
    3,390
    653
    Welcome to AAC!
    You could use a Divide by N counter such as CD4018.
  3. AnalogKid
    Aug 1, 2013
    4,708
    1,301
    And do what? Any counter circuit has an inputs and outputs.
    What is the voltage level of the bill accepter output signal?
    How long (wide) is its output signal?
    What is the power source for the counter circuit?
    Where does the counter output from the counter go? A display? A computer chip input?
    Does there have to be a way to reset the counter?
    Does the counter have to remember its number if it loses power?
    ak
  4. RichardO
    May 4, 2013
    1,346
    431
    I think that the bill accepter I used had relay contacts as the output. If yours is like this then you also have to debounce the relay contact signal before driving the counter input.
  5. Hypatia's Protege
    Mar 1, 2015
    2,850
    1,317
    Well... It seems your solution is vested in your question:cool: -- You need merely apply the conditioned pulses from the 'bill acceptor ' to a digital counter or, timing permitting, directly to a uC...
    Best regards
    HP:)
