The 10 Volts input voltage is the "ideal" situation.
With 12 Volts input the circuit will still work fine.
There only will be some more heat generated.
You will probably need a bit larger heatsink.
As for the capacitors, ceramic capacitors will be fine.
Bertus
Bertus
