Counter induced EMF
Discussion in 'Homework Help' started by johnalbert.aquilo, Apr 25, 2016.
  1. johnalbert.aquilo
    Apr 25, 2016
    • "Help me! Urgent!"
    Here is the question:
    A 500-hp, 600-volt DC motor operates at 495rpm at full load. If the flux per pole is 9.1webers and the armatute resistance is 15million-ohm and K-1.3 exp(-7). Calculate the counter induced EMF.
    Hopeful someone will give some shot to answer. Thank you in advanced :)
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I doubt anyone will give you an answer. If you show your work to the point you get stuck, it is highly likely that someone will guide you to the solution.
