Counter IC 12 step "Decade" counter ?
Discussion in 'General Electronics Chat' started by jpentecost, Feb 25, 2011.
  1. jpentecost
    Feb 25, 2011
    I have used the 4017 decade counter for a number of projects in the past and it's perfect. The trouble is that for this job I need to make a rotary indicator like a clock and I need to count to 12 or 16 (something that easily divides by four).
    I've routed around the internet and I can't find anything suitable .. There is an octal version of the 4017 (4022?) so in theory I could make a circuit to use two of them to make 16. But if anyone know of an off the shelf solution it would be perfect ..
  2. JDT
    Feb 12, 2009
    658
    85
    You need a 4-bit binary counter something like a 40161B (although there are other types) followed by a 4 to 16 line decoder like the 4514B. For 12 outputs use 0 - 11. You can make your counter reset to zero at 12.
    jpentecost likes this.
  3. jpentecost
    Feb 25, 2011
    I ended up using a HEF4514BP (simply because of easy availability) .. It works perfectly ..
    http://www.portablemotioncontrol.com/usync.html
