counter design
Discussion in 'Computing and Networks' started by arivvu, Dec 28, 2012.
  1. arivvu
    Sep 7, 2012
    9
    i need to design a 4bit counter (start counting from 0 to 15), using 3bit counter (which counts from 0 to 7).....can somebody help me....?
  2. Brownout
    Jan 10, 2012
    2,375
    998
    Simply not possible.
  3. davebee
    Oct 22, 2008
    539
    46
    If you ANDed the three output bits from the counter, and used the result to toggle a flipflop when the three bits are no longer all high, then you could use an output bit from the flipflop to provide the fourth bit.
  4. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Isn't it simpler than that? Each next bit is set HI, when the previous bit transitions from HI-LO.
    So it only need to detect HI->LO transition of the highest bit in the 3bit counter.
  5. WBahn
    Mar 31, 2012
    18,085
    4,917
    Does the 3-bit counter have a carry out?
    Do all four bits need to be synchronous?
    Should this be in the Homework Help forum?
  6. davebee
    Oct 22, 2008
    539
    46
    RB, I don't think so, because the 3rd bit will go high by itself when the 3 bit counter hits the count of 4. You only want to toggle the high bit when the 3 bit counter exits the count of 7, after all three bits have gone high.
  7. WBahn
    Mar 31, 2012
    18,085
    4,917
    If you are using it as a ripple counter, then you can clock the next stage by the falling edge of the msb of the prior counter segment. But if you want the two segments to be synchronous, then you need to detect the terminal state and use it as a count enable signal to the next stage.
  8. davebee
    Oct 22, 2008
    539
    46
    yes, you're right; my bad.
