counter circuits
Discussion in 'Homework Help' started by comsci, May 8, 2012.
  1. comsci
    May 8, 2012
    1) Using Logisim design design a 4-bit counter IC-1 that counts 0,1,2,3,... 9. The control inputs (Set Enable Clear) are each single input pins. (Using D flip flop).
    2) Using Logisim design design a 4-bit counter IC-1 that counts 0,1,2,3, ... F. The control inputs (Set Enable Clear) are each single input pins. (Using D Flip flop).
    Parts required from the Logisim library:
    A. Logic Gates
    B. Input Pin
    C. Output Pin
    D. Clock
    E. D Flip-Flop
    I don't know where to start, need help!!!
