Counter Circuit With A Control Input Design Problem
Discussion in 'Homework Help' started by thefunk, Jan 13, 2008.
  1. thefunk
    Jan 13, 2008
    hi,
    my question is like that design a counter circuit with a control input ( in addition to the clock input ) that counts odd numbers when the control input is high and counts even numbers when the control input is low.
    i have the state tables and k-maps, but i couldn't design the circuit. i'm hopeless, i have to send my report till 4 pm..
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Say you have a 4 bit binary number.
    Consider what bit in the 4-bit number is the same for all odd numbers and what bit in the 4-bit number is the same for all even numbers.
    hgmjr
  3. thefunk
    Jan 13, 2008
    3-bit 000 to 111
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Which bit determines odd/even? Spot this and you should be able to get started.
  5. scubasteve_911
    Dec 27, 2007
    1,202
  6. thefunk
    Jan 13, 2008
    when the control input is high (1) the circiut counts odd numbers,when the control input is low (0) the circuit counts even numbers.
    i designed before an odd number counter. Inout is provided by the clock. but here the control input is bothering me :)
  7. hgmjr
    Jan 28, 2005
    9,030
    214
    FSM stands for Finite State Machine in scubasteve_911's reply.
    hgmjr
