counter 0-12 rollover, DIGITAL circuits
Discussion in 'Homework Help' started by yey123, Sep 14, 2009.
  1. yey123
    Jul 20, 2008
    I've got a problem making this circuit...
    Using the combination of D FF and JK FF or 2 D FF, i have to make a circuit that will count from 0-12...
    can anyone suggest something if what gates am i going to use or to add. And what connection will I make for it to function.
    any suggestion will surely be appreciated,,
    tnx a lot..:D
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You could always look at a counter IC's internal logic, like a 74LS161.
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    You can't count to 12 with only 2 flipflops, never mind what type. You can only count from 0 to 3 with a pair. To count to 12 you need four flipflops. To compute this number you take the ceiling of log to the base 2 of the maximum count.
    Code ( (Unknown Language)):
    1.
    2. ceil(log 12/log 2) = ceil(1.079181246/0.301029995)
    3.  = ceil(3.584962501)
    4.  = 4
    5.
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    True, but the internal logic won't tell him how to go from the representation of 12 back to the representation of 0. In fact a designer may design the counter so it progresses through some other sequence of states like {3,4,5,6,7,8,9,10,11,12,13,14,15}. Most counters, like the 74xx161 have a TC output that makes this kind of syncronous reload a piece of cake.
  5. rjenkins
    Nov 6, 2005
    1,015
    69
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Indubiously! Except that the OP wants a divide by 13, as there are 13 elements(states) in the set {0,1,2,3,4,5,6,7,8,9,10,11,12}
