Countdown Timer
Discussion in 'The Projects Forum' started by JoeBro391, Jun 1, 2010.
  1. JoeBro391
    May 15, 2010
    68
    Hello, i'm looking for any tips on building a generic countdown timer to work with a 7-segment display. I have a really decent knowledge of electronics and and Integrated Circuits, but I don't currently know of which IC might be best for this project. I've built a countUP timer with a 4026 and it was pretty simple and I know how to manipulate all of the connections for the most part. (there's no way to have the 4026 count down, right?)
    Anyway, I don't want to use any type of Microcontroller and/or PIC or anything like that (that's something I'm currently just starting to read into); I want to do this soley with IC's. I heard that the 4029 might be what i'm looking for, but I also heard that I'd need a 7-segment decoder IC (a 4511?) to use in conjunction with the 4029 and a 7-segment display. Does anyone know of any IC's (what are they called? dividers in this instance, i'll assume. is that a proper assumption??) that will basically work in an opposite manner than the 4026 and have outputs made to work with a 7-segment display??? Thanks. -Joe
    PS: let me know if you need any clarifications as to my intent if these brief paragraphs were unclear
  2. Zaraphrax
    Mar 21, 2009
    47
    You could use a 74HC192 (http://focus.ti.com/docs/prod/folders/print/cd74hc192.html) to do the timing (it supports counting up AND down), which gives the output in BCD. You'll still need a BCD -> 7-seg encoder as you mentioned. To my knowledge and from a quick Google search, I couldn't find anything that outputs it in 7-seg code.
  3. BMorse
    Sep 26, 2009
    2,675
    234
  4. JoeBro391
    May 15, 2010
    68
    what's the encoder for then , if it outputs in BCD?? Is it so the lights of the display aren't more dim when the digit reads "8' opposed to "1" (because of the extra segments on)??? Or is BCD something different?? Thanks
    BMorse: thanks man, i'll check that out
    -Joe
  5. Zaraphrax
    Mar 21, 2009
    47
    BCD and 7-seg code are something different.
  6. JoeBro391
    May 15, 2010
    68
    aaaahhhh...that makes sense now. What exactly is BCD?? -Joe
  7. bertus
    Administrator
    Apr 5, 2008
    15,809
    2,390
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  9. JoeBro391
    May 15, 2010
    68
    thanks guys! -Joe
