countdown clock
Discussion in 'The Projects Forum' started by gizerandboots@sbcglobal.n, Jul 24, 2008.
  1. gizerandboots@sbcglobal.n
    Jul 24, 2008
    hello everyone,
    Im not an electronic savy person what im doing hear is trying to kind a countdown clock for my christmas display.
    I have looked around the web and im not willing to spend $300 plus.
    I was hopeing one of the real smart people here would be able to point me in the right direction to build my own. now i have built a christmas light sequense controller so I am able to build electronic stuff, i just need the design,
    what im looking to build is a display showing days, hours, min, sec, and mili sec would be real cool, and would like the display to be 4 inches tall or so and have it countdown to a particular day i program in (in my case christmas)
    Can this be done for around $100???
    any help would be welcome
    THANKS,
    scott
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    The short answer is yes, but the catch is finding the plans. The parts aren't that expensive, but it will take know how.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    This is one of those calendar and time manipulation problems that would lend itself wonderfully to a microcontroller.
    There are plenty of time and date manipulation algorythms out there.
    There are modules that can obtain the precise time from NIST WWV's 60KHz signal.
    http://tf.nist.gov/stations/wwv.html
    It's just a matter of hooking them up, and writing the code to calculate the difference, and display it on something.
  4. gizerandboots@sbcglobal.n
    Jul 24, 2008
    your last sentenance is my whole problem or should i say chalange.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, what kind of research have you done?
    BTW, we have no clue where you live, so we don't know if the NIST WWV time signal is even available or relevant to you.
    In the meantime, look up the datasheet for a U4226B IC. It's a time code receiver.
    Unless you integrate a timecode receiver into your design, your microcontroller (below called uC) predictions might start off OK (if you've set the time correctly) but will soon drift through the "well, close" category to the "wildly inaccurate" realm.
    Plainly speaking, it's impossible to achieve decent long-term accuracy (stability) with the internal clock of a uC. It's very difficult to achieve even with very expensive equipment.
    That's where the timecode receiver comes in. You can get the exact time loaded right into your uC, if you can figure it out.
    You have a rather steep learning curve ahead of you. Even if you make no mistakes, your costs could easily exceed your target budget, depending upon which uC you start with, and your ability to learn the language spoken by it.
  6. gizerandboots@sbcglobal.n
    Jul 24, 2008
    thanks for your help it looks like what i need to do is buy one.
