Count to 12 or 15 using IC4017
Discussion in 'General Electronics Chat' started by shivaaa, Feb 8, 2011.
  1. shivaaa
    Jan 5, 2011
    55
    Is it possible to count to 12 or 15 using 4017, I know how to count to Less than 10, Count to 10 and count to 100. But is there any way to count to 12 or 15 like that?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You would need to cascade two 4017 counters.
    This is one way to cascade them:
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    It may not have to be that complicated. To the OP, do you want a sequencer, 15 outputs with only one on, or are you wanting a counter, with a one's place and a 10's place?
    I've had other posts (on the 4017) where the assumption bit me.
  4. shivaaa
    Jan 5, 2011
    55
    I am trying to Make a clock using only 4017 ICs. So I want to start to count from second, Mins then hour. I want Just 12 OPs for this.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
  6. shivaaa
    Jan 5, 2011
    55
    Wow.. I saw the Making Patterns. I think this is wat i need.. Let me try this... Thanks a lot bill
  7. shivaaa
    Jan 5, 2011
    55
    HI, Please have a look at the attached image, counting to 12, plz let me know is it correct?
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    Pretty close, it will work. Look at Figure 12.3 for a comparison.
    Are you going to make a 60 step sequencer for minutes and seconds?
  9. shivaaa
    Jan 5, 2011
    55
    No, I am not going to Use 60 step sequencer, I want to reduce it around 10 for Sec, Minute and hour also, May be for Seconds I may use different Step like 10 or less.
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
