Count number of logic 1's in 7 bit number
Discussion in 'Homework Help' started by ppd, Feb 11, 2011.
  1. ppd
    Feb 11, 2011
    What is the simplest logic circuit to count the number of logic ones in a 7 bit input, using only half adders and full adders?
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    Since you will be using adders, try to see the operation as a sum of numbers. You have 7 numbers, the figures of your 7-bit number. All 7 numbers are 1-bit long. Let's name the figures of your number b0-b6, from the LSB to the MSB. Let's break down the operation:
    Using a 1-bit Full Adder you can add 3 1-bit numbers (1st summand, 2nd summand, Carry-in) and get a 2-bit number.
    Thus you can sum b0,b1,b2 with one FA, and b3,b4,b5 with a second FA.
    You now have 2 2-bit numbers and one 1-bit number, the b6.
    Using a 2-bit FA (which is made of 2 1-bit FA), you can add 2 2-bit numbers and 1 1-bit number (the carry in). You already have the 2 2-bit numbers as the result of the 2 previous additions, and the b6 will be used as the carry-in.
    In the end, you end up wit 1 3-bit number, which can have a maximum value of 7.
    In that implementation we used 4 Full Adders.
    Is that clear?
    Tirumala and saichand like this.
  3. ppd
    Feb 11, 2011
    That was perfectly clear. Thank you!
    Tirumala likes this.
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    I 'll keep asking until someone answers "Crystal!".
    Then I 'll keep asking some more...
    shankariyer96 likes this.
