I think you are on the right track. It's bit hard to follow which FAs you are talking about when. It would help if you could through a sketch together (Something simple in Paint will do fine) to make it all clear.Sorry, you are right.. I should explain myself.
I have been thinking ,as a beginning, using 2 full adders.
Lets say the number would be presented as a0a1...a6
So the first FA will get a0,a1,a2
The second FA a3,a4,a5
Than using another FA with the a6 bit, and connect the sums of the two, and then use another FA to the Carry of the 2 FA..
But I am not sure its best solution..
Any ideas?
1) His constraints won't let him use anything by Half Adders and Full Adders.If the 7-bit input is loaded into a shift register you can examine the bits one at a time with seven clock pulses. You need a 3-bit counter with an enable. You have a state machine that examines a data bit and increments the counter if it is a '1' and holds the present state it it is a '0. The states would be:
{LOAD, BIT0, BIT1, BIT2, BIT3, BIT4, BIT5, BIT6, DONE}
Input would be START and outputs would be the 3-bit counter
But that's not what he's trying to do. The OP's description of what he is trying to do and the constraints he is working under were actually among the better descriptions we have seen lately.If you want to count the number of ones in order to determine the parity simply use a parity encoder.
by Aaron Carman
by Aaron Carman
by Jake Hertz
by Jake Hertz
